Introducción
Use this guide to replace a nonfunctional MIC Port or Remote Socket on your EOS 6D.
Qué necesitas
Remove the viewfinder cover by pinching the sides and sliding it upward.
Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
Rotate the camera so the bottom is facing you.
Use the spudger to remove the light brown ribbon wire from the bottom edge of the camera.
2 personas más completaron esta guía.
