Introducción
Use this guide to replace the front or top body panels of your EOS 6D or to access damaged internal components.
Qué necesitas
Remove the viewfinder cover by pinching the sides and sliding it upward.
Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
13 personas más completaron esta guía.
7Guía Comentarios
In step 11 one of the red circles marks incorrect screw - should point the one near plate not the one in battery compartment (compare to step 6)
Agreed.
But thanks, apart from this minor error it was a great help and really clear. Cleaned the gunge out of the menu button and it now releases perfectly.
I found getting the ribbon cable back in (step 21) a bit difficult, combo wiggled and pushed it back in. Might recommend doing that one before the right one, and maybe before finally mounting the top cover.
Blakey -
