Introducción
Use this guide to replace a cracked or malfunctioning top analog screen on your EOS 6D.
Qué necesitas
Remove the viewfinder cover by pinching the sides and sliding it upward.
Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
Use the pointed end of the spudger to flip up two silver ribbon wire latches on the inside of the top panel.
9 personas más completaron esta guía.
2 comentarios
any way to replace the sd card side panel without having to take the lcd panel off
