Introducción
Use this guide to replace a cracked or malfunctioning top analog screen on your EOS 6D.
Qué necesitas
Remove the viewfinder cover by pinching the sides and sliding it upward.
Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
Rotate the covers to the side so that you can see the connection ports inside.
Remove the following screws:
Two silver 5mm Phillips #00
One black 6mm Phillips #00
Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
Use the pointed end of the spudger to flip up two silver ribbon wire latches on the inside of the top panel.
9 personas más completaron esta guía.
2 comentarios
any way to replace the sd card side panel without having to take the lcd panel off
