Saltar al contenido principal
Canon EOS 60D: Replacing Eye piece and Battery door
  1. Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: paso 1, imagen 1 de 2 Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: paso 1, imagen 2 de 2
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Canon EOS 60D: Replacing Eye piece and Battery door: paso 2, imagen 1 de 2 Canon EOS 60D: Replacing Eye piece and Battery door: paso 2, imagen 2 de 2
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
Conclusión
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
4 personas más completaron esta guía.
Eric D
Miembro Desde 11/13/12
1,284 Reputación
5 Guías creadas
Un comentario
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 5,925
