Saltar al contenido principal
Canon EOS 60D Rubber grips Replacement
Qué necesitas
  1. Canon EOS 60D Rubber grips Replacement, Rubber grips: paso 1, imagen 1 de 1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
Conclusión
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
10 personas más completaron esta guía.
Eric D
Miembro Desde 11/13/12
1,284 Reputación
5 Guías creadas
Un comentario
Where can we get replacement grips?
Luke Lin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 25
Todo El Tiempo: 11,907
