Saltar al contenido principal
Canon EOS 60D Rear LCD Screen Replacement
Qué necesitas
  1. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen Dissasembly: paso 1, imagen 1 de 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Replacement: paso 3, imagen 1 de 2 Canon EOS 60D Rear LCD Screen Replacement: paso 3, imagen 2 de 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: paso 5, imagen 1 de 2 Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: paso 5, imagen 2 de 2
    • Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
    • Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
  6. Canon EOS 60D Rear LCD Screen Replacement: paso 6, imagen 1 de 1
    • Finally, remove the LCD screen by grabbing the clear plastic tab and lifting it carefully.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 16-6, Wollert Fall 2015 Miembro de USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 72
Todo El Tiempo: 7,709
