Saltar al contenido principal
Canon EOS 60D Rear Cover Removal
Qué necesitas
  1. Canon EOS 60D Rear Cover Removal, Rear LCD Screen Dissasembly: paso 1, imagen 1 de 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear Cover Removal: paso 2, imagen 1 de 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear Cover Removal: paso 3, imagen 1 de 2 Canon EOS 60D Rear Cover Removal: paso 3, imagen 2 de 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear Cover Removal: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear Cover Removal, Removing Rear Cover: paso 5, imagen 1 de 2 Canon EOS 60D Rear Cover Removal, Removing Rear Cover: paso 5, imagen 2 de 2
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
  6. Canon EOS 60D Rear Cover Removal: paso 6, imagen 1 de 2 Canon EOS 60D Rear Cover Removal: paso 6, imagen 2 de 2
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
  7. Canon EOS 60D Rear Cover Removal: paso 7, imagen 1 de 1
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
  8. Canon EOS 60D Rear Cover Removal: paso 8, imagen 1 de 2 Canon EOS 60D Rear Cover Removal: paso 8, imagen 2 de 2
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
  9. Canon EOS 60D Rear Cover Removal: paso 9, imagen 1 de 2 Canon EOS 60D Rear Cover Removal: paso 9, imagen 2 de 2
    • Using the plastic opening tool, carefully pry off the the side cover.
  10. Canon EOS 60D Rear Cover Removal: paso 10, imagen 1 de 1
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
  11. Canon EOS 60D Rear Cover Removal: paso 11, imagen 1 de 1
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
  12. Canon EOS 60D Rear Cover Removal: paso 12, imagen 1 de 1
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
Conclusión
Una persona más ha completado esta guía.
Tyler Vaal
Miembro Desde 08/30/15
695 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 16-6, Wollert Fall 2015 Miembro de USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 2,417
