Saltar al contenido principal
Canon EOS 60D Left-Side Port Cover Replacement
Qué necesitas
  1. Canon EOS 60D Left-Side Port Cover Replacement, Rubber grips: paso 1, imagen 1 de 1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
  2. Canon EOS 60D Left-Side Port Cover Replacement, Left-Side Port Cover: paso 2, imagen 1 de 1
    • Remove 3 screws
    • Remove the small Screw under the Flip cover too
  3. Canon EOS 60D Left-Side Port Cover Replacement: paso 4, imagen 1 de 1
    • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
    • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
    • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
  4. Canon EOS 60D Left-Side Port Cover Replacement: paso 5, imagen 1 de 1
    • Slide the rear part of the cover out.
  5. Canon EOS 60D Left-Side Port Cover Replacement: paso 6, imagen 1 de 2 Canon EOS 60D Left-Side Port Cover Replacement: paso 6, imagen 2 de 2
    • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
    • Slide down to remove without damaging the cover. (see photo with cover removed)
    • You can see how the cover, and side piece fit together in the second image.
Conclusión
7 personas más completaron esta guía.
Eric D
Miembro Desde 11/13/12
1,311 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 7,324
