Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This will allow you access to the ports, or if you need to replace the dust cover, will allow you to do that.
Partes
No se especificaron partes.
  1. Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
  2. Remove 3 screws
    • Remove 3 screws
  3. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
    • Remove the small Screw under the Flip cover too
  4. Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
    • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
    • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
    • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
  5. Slide the rear part of the cover out.
    • Slide the rear part of the cover out.
  6. At this point, the only thing holding on is the dust-cover is hooked onto the front panel Slide down to remove without damaging the cover.  (see photo with cover removed)
    • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
    • Slide down to remove without damaging the cover. (see photo with cover removed)
    • You can see how the cover, and side piece fit together in the second image.
Conclusión
6 personas más completaron esta guía.
Eric D
Miembro Desde 13/11/12
1,143 Reputación
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 6,129
