Saltar al contenido principal
Canon EOS 40D Shutter Assembly Replacement
Qué necesitas
  1. Canon EOS 40D Shutter Assembly Replacement, Shutter Assembly: paso 1, imagen 1 de 1
    • Get the Canon 40D Service Repair Manual
    • Have a clean and organized workspace. I labelled plastic trays by step number and put all items for each step in a separate tray.
    • Watch a couple Youtube videos on this process
  2. Canon EOS 40D Shutter Assembly Replacement: paso 2, imagen 1 de 2 Canon EOS 40D Shutter Assembly Replacement: paso 2, imagen 2 de 2
    • Peel off rubber grips
  3. Canon EOS 40D Shutter Assembly Replacement: paso 3, imagen 1 de 1
    • take off front piece
  4. Canon EOS 40D Shutter Assembly Replacement: paso 4, imagen 1 de 2 Canon EOS 40D Shutter Assembly Replacement: paso 4, imagen 2 de 2
    • take off rear
    • connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
  5. Canon EOS 40D Shutter Assembly Replacement: paso 5, imagen 1 de 3 Canon EOS 40D Shutter Assembly Replacement: paso 5, imagen 2 de 3 Canon EOS 40D Shutter Assembly Replacement: paso 5, imagen 3 de 3
    • Take off top cover
  6. Canon EOS 40D Shutter Assembly Replacement: paso 6, imagen 1 de 3 Canon EOS 40D Shutter Assembly Replacement: paso 6, imagen 2 de 3 Canon EOS 40D Shutter Assembly Replacement: paso 6, imagen 3 de 3
    • take off bottom plate
    • disconnect and remove bottom board
  7. Canon EOS 40D Shutter Assembly Replacement: paso 7, imagen 1 de 1
    • remove CMOS assembly
  8. Canon EOS 40D Shutter Assembly Replacement: paso 8, imagen 1 de 1
    • remove metal back
    • remove and replace shutter assembly, transfering components that aren't on the new one
Conclusión
6 personas más completaron esta guía.
2 comentarios
how do you replace the bridge (male portion on camera) other than putting the card in a card reader
wareibevictoriap - Contestar
how to replace the focus lock beeper
Dave Reitner - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 29
Todo El Tiempo: 7,280
