Saltar al contenido principal
Canon EOS 40D Flash Hot Shoe Replacement
Qué necesitas
  1. Canon EOS 40D Flash Hot Shoe Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Flash Hot Shoe Replacement: paso 2, imagen 1 de 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Flash Hot Shoe Replacement: paso 3, imagen 1 de 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: paso 4, imagen 1 de 3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: paso 4, imagen 2 de 3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: paso 4, imagen 3 de 3
    • Use a metal spudger or opening tool to gently lift the hotshoe plate and slide it off.
  5. Canon EOS 40D Flash Hot Shoe Replacement: paso 5, imagen 1 de 3 Canon EOS 40D Flash Hot Shoe Replacement: paso 5, imagen 2 de 3 Canon EOS 40D Flash Hot Shoe Replacement: paso 5, imagen 3 de 3
    • Remove the four 4.0 mm Phillips #000 screws securing the flash shoe to the camera.
    • Remove the flash shoe.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team 12-3, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Miembros
16 Guías creadas
Un comentario
This is the best down to earth instructions i have ever had. No messing about even tells what screws and how to open the battery cover
Albert
albert irving - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 36
Todo El Tiempo: 4,483
