Saltar al contenido principal
Canon EOS 40D Date and Time Battery Replacement
Qué necesitas
  1. Canon EOS 40D Date and Time Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Date and Time Battery Replacement: paso 2, imagen 1 de 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Date and Time Battery Replacement: paso 3, imagen 1 de 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: paso 4, imagen 1 de 3 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: paso 4, imagen 2 de 3 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: paso 4, imagen 3 de 3
    • Remove the date and time battery holder by sliding it out of the slot.
  5. Canon EOS 40D Date and Time Battery Replacement: paso 5, imagen 1 de 1
    • Remove the date and time battery from the battery holder.
Conclusión
8 personas más completaron esta guía.
Doug Kruse
Miembro Desde 09/03/15
745 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 12-3, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Miembros
16 Guías creadas
5 comentarios
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
David Drinkwater - Contestar
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Stephen Spratley - Contestar
This was so helpful, thank you! Also if you are in a jam and do not have a CR2016, you can use a CR2032 directly without using the normal battery tray.
paniak - Contestar
Great help! Accurate, easy to follow directions
Jack Applegate - Contestar
Excellent. Just what I needed, to bring life back to the dead.
pvlewisnz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 27
Ultimos 30 días: 117
Todo El Tiempo: 14,581
