Saltar al contenido principal
Canon EOS 300 Eyepiece Replacement
Qué necesitas
  1. Canon EOS 300 Eyepiece Replacement, Batteries: paso 1, imagen 1 de 3 Canon EOS 300 Eyepiece Replacement, Batteries: paso 1, imagen 2 de 3 Canon EOS 300 Eyepiece Replacement, Batteries: paso 1, imagen 3 de 3
    • Open up the battery door.
  2. Canon EOS 300 Eyepiece Replacement: paso 2, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 2, imagen 2 de 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Eyepiece Replacement, Side Panel with Lever: paso 3, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement, Side Panel with Lever: paso 3, imagen 2 de 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Eyepiece Replacement: paso 4, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 4, imagen 2 de 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Eyepiece Replacement: paso 5, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 5, imagen 2 de 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Eyepiece Replacement, Front Panel: paso 6, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement, Front Panel: paso 6, imagen 2 de 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Eyepiece Replacement: paso 7, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 7, imagen 2 de 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Eyepiece Replacement: paso 8, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 8, imagen 2 de 2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Eyepiece Replacement, Bottom Panel: paso 9, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement, Bottom Panel: paso 9, imagen 2 de 2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Eyepiece Replacement: paso 10, imagen 1 de 3 Canon EOS 300 Eyepiece Replacement: paso 10, imagen 2 de 3 Canon EOS 300 Eyepiece Replacement: paso 10, imagen 3 de 3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Eyepiece Replacement, Side Panel with Grip: paso 11, imagen 1 de 3 Canon EOS 300 Eyepiece Replacement, Side Panel with Grip: paso 11, imagen 2 de 3 Canon EOS 300 Eyepiece Replacement, Side Panel with Grip: paso 11, imagen 3 de 3
    • Remove the remote control socket cover.
  12. Canon EOS 300 Eyepiece Replacement: paso 12, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 12, imagen 2 de 2
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Eyepiece Replacement: paso 13, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 13, imagen 2 de 2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Eyepiece Replacement: paso 14, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 14, imagen 2 de 2
    • Pry open the side grip using a spudger.
  15. Canon EOS 300 Eyepiece Replacement, Eyecup: paso 15, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement, Eyecup: paso 15, imagen 2 de 2
    • With your hands, remove the rubber grip from the eye piece.
  16. Canon EOS 300 Eyepiece Replacement: paso 16, imagen 1 de 1
    • Remove the eyecup from the eyepiece by pushing the eyecup up.
  17. Canon EOS 300 Eyepiece Replacement, Top Panel: paso 17, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement, Top Panel: paso 17, imagen 2 de 2
    • Remove two silver 5.0mm Phillips #1 screws.
  18. Canon EOS 300 Eyepiece Replacement: paso 18, imagen 1 de 1
    • Remove the silver 5.5mm Phillips #1 screw.
  19. Canon EOS 300 Eyepiece Replacement: paso 19, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement: paso 19, imagen 2 de 2
    • Pry the top silver part of the camera off.
    • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
  20. Canon EOS 300 Eyepiece Replacement, Eyepiece: paso 20, imagen 1 de 2 Canon EOS 300 Eyepiece Replacement, Eyepiece: paso 20, imagen 2 de 2
    • Remove the two black 9.5mm screws.
  21. Canon EOS 300 Eyepiece Replacement: paso 21, imagen 1 de 3 Canon EOS 300 Eyepiece Replacement: paso 21, imagen 2 de 3 Canon EOS 300 Eyepiece Replacement: paso 21, imagen 3 de 3
    • Remove two black 8.8mm Phillips #1 screws with a screw driver.
    • Remove the right screw first (the one without the tape).
Conclusión
Tammy Kong
Miembro Desde 01/23/14
765 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-20, Maness Winter 2014 Miembro de Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Miembros
32 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 656
