Saltar al contenido principal
Canon ELPH Z3 Camera Rear Screen Replacement
Qué necesitas
  1. Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: paso 1, imagen 1 de 3 Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: paso 1, imagen 2 de 3 Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: paso 1, imagen 3 de 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Rear Screen Replacement: paso 2, imagen 1 de 3 Canon ELPH Z3 Camera Rear Screen Replacement: paso 2, imagen 2 de 3 Canon ELPH Z3 Camera Rear Screen Replacement: paso 2, imagen 3 de 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Rear Screen Replacement: paso 3, imagen 1 de 2 Canon ELPH Z3 Camera Rear Screen Replacement: paso 3, imagen 2 de 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Rear Screen Replacement: paso 4, imagen 1 de 3 Canon ELPH Z3 Camera Rear Screen Replacement: paso 4, imagen 2 de 3 Canon ELPH Z3 Camera Rear Screen Replacement: paso 4, imagen 3 de 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: paso 5, imagen 1 de 2 Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: paso 5, imagen 2 de 2
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Rear Screen Replacement: paso 6, imagen 1 de 3 Canon ELPH Z3 Camera Rear Screen Replacement: paso 6, imagen 2 de 3 Canon ELPH Z3 Camera Rear Screen Replacement: paso 6, imagen 3 de 3
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Rear Screen Replacement: paso 7, imagen 1 de 2 Canon ELPH Z3 Camera Rear Screen Replacement: paso 7, imagen 2 de 2
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
Conclusión
Katy Skillings
Miembro Desde 10/21/16
1 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-7, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 203
