Saltar al contenido principal
Canon ELPH Z3 Camera Film Chamber Replacement
Qué necesitas
  1. Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: paso 1, imagen 1 de 3 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: paso 1, imagen 2 de 3 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: paso 1, imagen 3 de 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Film Chamber Replacement: paso 2, imagen 1 de 3 Canon ELPH Z3 Camera Film Chamber Replacement: paso 2, imagen 2 de 3 Canon ELPH Z3 Camera Film Chamber Replacement: paso 2, imagen 3 de 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Film Chamber Replacement: paso 3, imagen 1 de 2 Canon ELPH Z3 Camera Film Chamber Replacement: paso 3, imagen 2 de 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Film Chamber Replacement: paso 4, imagen 1 de 3 Canon ELPH Z3 Camera Film Chamber Replacement: paso 4, imagen 2 de 3 Canon ELPH Z3 Camera Film Chamber Replacement: paso 4, imagen 3 de 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Film Chamber Replacement, Film: paso 5, imagen 1 de 2 Canon ELPH Z3 Camera Film Chamber Replacement, Film: paso 5, imagen 2 de 2
    • Separate the front and back coverings of the camera completely.
    • Remove both coverings from the body of the camera.
    • Flip the camera upside down and focus on the bottom right portion.
  6. Canon ELPH Z3 Camera Film Chamber Replacement: paso 6, imagen 1 de 3 Canon ELPH Z3 Camera Film Chamber Replacement: paso 6, imagen 2 de 3 Canon ELPH Z3 Camera Film Chamber Replacement: paso 6, imagen 3 de 3
    • Unscrew the 4.1mm screw using a PH000 screwdriver.
    • Swivel the now loose metal portion to the right.
    • This action will open the film chamber and thus exposing the film.
  7. Canon ELPH Z3 Camera Film Chamber Replacement: paso 7, imagen 1 de 3 Canon ELPH Z3 Camera Film Chamber Replacement: paso 7, imagen 2 de 3 Canon ELPH Z3 Camera Film Chamber Replacement: paso 7, imagen 3 de 3
    • Press gently on the film using your finger to slightly eject the film.
    • Pull the film from the chamber.
Conclusión
Equipo
UMass Dartmouth, Team 1-7, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 922
