Saltar al contenido principal
Canon ELPH Z3 Camera Battery Replacement
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: paso 1, imagen 1 de 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: paso 1, imagen 2 de 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: paso 1, imagen 3 de 3
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: paso 2, imagen 1 de 2 Canon ELPH Z3 Camera Battery  Replacement: paso 2, imagen 2 de 2
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
Conclusión
Nathan Barros
Miembro Desde 10/18/16
1 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-7, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 30
Todo El Tiempo: 766
