Saltar al contenido principal
Canon CanoScan N670U Sensor Bar Replacement
Qué necesitas
  1. Canon CanoScan N670U Sensor Bar Replacement, Canon CanoScan N670U Disassembly: paso 1, imagen 1 de 1
    • Open up your Canon CanoScan N670U to an upright position.
  2. Canon CanoScan N670U Sensor Bar Replacement: paso 2, imagen 1 de 1
    • Turn your device so that you're facing the long side of the Canon CanoScan N670U.
    • Locate the small crevice between the plastic components of the scanner bed and the scanner base.
  3. Canon CanoScan N670U Sensor Bar Replacement: paso 3, imagen 1 de 1
    • Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
    • You may cut small bits of the plastic as you're slicing the adhesive. Do not forcefully bend the plastic strip as you're cutting or it will snap.
  4. Canon CanoScan N670U Sensor Bar Replacement: paso 4, imagen 1 de 1
    • Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
  5. Canon CanoScan N670U Sensor Bar Replacement: paso 5, imagen 1 de 1
    • Repeat steps 2-4 for the other side of the scanner.
  6. Canon CanoScan N670U Sensor Bar Replacement: paso 6, imagen 1 de 1
    • Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
  7. Canon CanoScan N670U Sensor Bar Replacement: paso 7, imagen 1 de 1
    • Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
  8. Canon CanoScan N670U Sensor Bar Replacement: paso 8, imagen 1 de 1
    • Slowly pull the glass scanner bed towards you and set the piece aside.
  9. Canon CanoScan N670U Sensor Bar Replacement, Sensor Bar: paso 9, imagen 1 de 1
    • This is the sensor bar that you will replace.
  10. Canon CanoScan N670U Sensor Bar Replacement: paso 10, imagen 1 de 2 Canon CanoScan N670U Sensor Bar Replacement: paso 10, imagen 2 de 2
    • Locate the small plug where the white strip of cable is connected to.
    • Unfurl the cable strip if it's tucked in.
  11. Canon CanoScan N670U Sensor Bar Replacement: paso 11, imagen 1 de 3 Canon CanoScan N670U Sensor Bar Replacement: paso 11, imagen 2 de 3 Canon CanoScan N670U Sensor Bar Replacement: paso 11, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Gently use tweezers or your fingers to rock the cable back and forth to disconnect the it.
    • Do not apply too much pressure or you may damage some delicate components.
  12. Canon CanoScan N670U Sensor Bar Replacement: paso 12, imagen 1 de 1
    • Locate the small metal spring behind the front buttons of the Canon CanoScan N670U.
  13. Canon CanoScan N670U Sensor Bar Replacement: paso 13, imagen 1 de 2 Canon CanoScan N670U Sensor Bar Replacement: paso 13, imagen 2 de 2
    • Use tweezers to gently remove the metal spring from the plastic hook.
    • Due to the tension of the spring, it can be difficult to pull the metal end. You may attempt to use your hands to pull the spring itself if necessary.
    • Take caution to not bend the metal.
  14. Canon CanoScan N670U Sensor Bar Replacement: paso 14, imagen 1 de 2 Canon CanoScan N670U Sensor Bar Replacement: paso 14, imagen 2 de 2
    • Flip the sensor bar over and unwind the belt from the gear system.
  15. Canon CanoScan N670U Sensor Bar Replacement: paso 15, imagen 1 de 1
    • Remove the sensor bar from the scanner and replace it with the new one.
Conclusión
Una persona más ha completado esta guía.
Stephen Bui
Miembro Desde 09/19/15
558 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 796
