Introducción
If you're encountering issues as a result from the scanner bed, this is where you will want to start.
To replace the glass scanner bed, you must:
- Remove the two plastic bars that holds the scanner bed in place.
- Carefully remove the glass scanner bed to add the replacement.
Qué necesitas
Open up your Canon CanoScan N670U to an upright position.
Una persona más ha completado esta guía.
