Introducción
We are removing the old light filter foam and replacing it with new foam in your Canon AE-1. This will help keep light out of the inner case so that it doesn't wreck the film.
Qué necesitas
Open the film compartment by pulling on the release pin.
Use a 3mm slot screw driver to scrape old light filter foam cleanly off.
Then use Isopropyl Alcohol to assist in removing the old light filter foam.
To reassemble your device, follow these instructions.
2 personas más completaron esta guía.
