Saltar al contenido principal
Canon A35F Battery Replacement
Qué necesitas
  1. Canon A35F Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the Canon A35F on its top so that the bottom of the camera is facing up.
    • Spot the two windows on the bottom of the camera (each window has the word "OPEN" written, and an arrow, both pointing the same direction).
    • Use your fingernail (or a iFixit opening tool), and push in the direction of the arrow to open the left compartment.
  2. Canon A35F Battery Replacement: paso 2, imagen 1 de 1
    • Wipe the PX-625 mercury battery with a clean cloth, so that there are no unnecessary fingerprints on the battery.
    • Place the mercury battery in the slot with the yellow ribbon.
    • Make sure to place it in the right side! If it is facing the wrong direction, the shutter will be locked and the meter needle will not move to the battery check zone.
    • Make sure not to leave fingerprints on the battery. It may cause corrosion to the camera's electric contact.
  3. Canon A35F Battery Replacement: paso 3, imagen 1 de 1
    • Shut the left window close.
  4. Canon A35F Battery Replacement: paso 4, imagen 1 de 1
    • Use your fingernail (or a iFixit opening tool), and push in the direction of the arrow to open the right compartment.
  5. Canon A35F Battery Replacement: paso 5, imagen 1 de 1
    • Insert the size AA battery, for the flash, into the compartment (make sure to insert the battery in the right direction).
  6. Canon A35F Battery Replacement: paso 6, imagen 1 de 1
    • Shut the right window close.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 25
Ultimos 30 días: 111
Todo El Tiempo: 3,914
