Introducción
This guide will show you how to replace your square port by unscrewing the plastic casing that holds it, unpeeling the ribbon cable that attaches it to the case, and unplugging one end of the ribbon cable that will free the entire port.
Herramientas
Partes
No se especificaron partes.
Slide the plastic opening tool under the plastic to unpeel it from the glass.
Gently pry the plastic framing from the glass.
Repeat on the other side.
Casi Terminas!
Conclusión
