Saltar al contenido principal
Canary CAN100USBK Ethernet PCB Board Replacement
Qué necesitas
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: paso 1, imagen 1 de 2 Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: paso 1, imagen 2 de 2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Ethernet PCB Board Replacement: paso 2, imagen 1 de 1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Ethernet PCB Board Replacement: paso 3, imagen 1 de 3 Canary CAN100USBK Ethernet PCB Board Replacement: paso 3, imagen 2 de 3 Canary CAN100USBK Ethernet PCB Board Replacement: paso 3, imagen 3 de 3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Ethernet PCB Board Replacement: paso 4, imagen 1 de 2 Canary CAN100USBK Ethernet PCB Board Replacement: paso 4, imagen 2 de 2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Ethernet PCB Board Replacement: paso 5, imagen 1 de 2 Canary CAN100USBK Ethernet PCB Board Replacement: paso 5, imagen 2 de 2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: paso 6, imagen 1 de 1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Ethernet PCB Board Replacement: paso 7, imagen 1 de 2 Canary CAN100USBK Ethernet PCB Board Replacement: paso 7, imagen 2 de 2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Ethernet PCB Board Replacement: paso 8, imagen 1 de 1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
Conclusión
Tommy Nguyen
Miembro Desde 02/28/17
597 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G2, Nance Spring 2017 Miembro de USF Tampa, Team S1-G2, Nance Spring 2017
USFT-NANCE-S17S1G2
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 909
