Saltar al contenido principal
Campbell Hausfeld FP204800 Thumb Screw Drain Replacement
Qué necesitas
  1. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Remove Thumb Screw Drain: paso 1, imagen 1 de 1
    • Remove the thumb screw drain from the bottom of the compressor using a Smart Wrench.
    • The thumb screw may not easily be removed due to corrosion.
  2. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Apply Teflon Tape: paso 2, imagen 1 de 1
    • Apply teflon tape to the replacement thumb screw drain.
    • The teflon tape should be wound tightly around the entire threaded portion of the thumb screw drain.
    • When you reassemble the thumb screw drain on the compressor, make sure to fully tighten it using a Smart Wrench.
Conclusión
Eric
Miembro Desde 10/09/14
409 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 14-29, Maness Fall 2014 Miembro de Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 400
