Saltar al contenido principal
Campbell Hausfeld FP204800 Pressure Gauge Replacement
Qué necesitas
  1. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: paso 1, imagen 1 de 3 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: paso 1, imagen 2 de 3 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: paso 1, imagen 3 de 3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: paso 2, imagen 1 de 2 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: paso 2, imagen 2 de 2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: paso 3, imagen 1 de 1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the On/Off Switch Wiring: paso 4, imagen 1 de 1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: paso 5, imagen 1 de 2 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: paso 5, imagen 2 de 2
    • Using a Smart Wrench, remove the old/broken pressure gauge or gauges.
Conclusión
2 personas más completaron esta guía.
Eric
Miembro Desde 10/09/14
409 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 14-29, Maness Fall 2014 Miembro de Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 976
