Saltar al contenido principal
Cambridge Audio A3i Motherboard Replacement
Qué necesitas
  1. Cambridge Audio A3i Motherboard Replacement, Case: paso 1, imagen 1 de 1
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Motherboard Replacement: paso 3, imagen 1 de 2 Cambridge Audio A3i Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Motherboard Replacement: paso 4, imagen 1 de 1
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
  6. Cambridge Audio A3i Motherboard Replacement: paso 6, imagen 1 de 1
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
  7. Cambridge Audio A3i Motherboard Replacement: paso 7, imagen 1 de 2 Cambridge Audio A3i Motherboard Replacement: paso 7, imagen 2 de 2
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
Conclusión
Una persona más ha completado esta guía.
Colby
Miembro Desde 04/15/10
338 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 28-36, Regan Spring 2010 Miembro de Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 29
Todo El Tiempo: 6,624
