Saltar al contenido principal
Introducción
Prerequisite-only guide to disconnect the cables on an HTC Vive.
  1. Be sure to power down and disconnect your Vive before beginning. Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset. Lift the cover away from the headset and slide it up the cables until it's out of the way.
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  2. Lift the HDMI cable straight up to unplug it from the headset. Lift the HDMI cable straight up to unplug it from the headset.
    • Lift the HDMI cable straight up to unplug it from the headset.
  3. Repeat the lifting and unplugging process with the remaining USB, power, and audio cables. Repeat the lifting and unplugging process with the remaining USB, power, and audio cables. Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
Conclusión
Adam O'Camb
Miembro Desde 11/04/15
140,548 Reputación
407 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
138 Miembros
16,477 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 12
