Saltar al contenido principal
Cabinet Magnetic Catch Replacement
Qué necesitas
  1. Cabinet Magnetic Catch Replacement, Cabinet Magnet Catch: paso 1, imagen 1 de 2 Cabinet Magnetic Catch Replacement, Cabinet Magnet Catch: paso 1, imagen 2 de 2
    • Remove two screws from the the old magnetic catch using a Phillips #0 screwdriver.
    • Remove the magnetic catch from the shelf.
    • It is recommended you use a stubby screwdriver since you will be dealing with tight spaces of the cabinet shelf.
  2. Cabinet Magnetic Catch Replacement: paso 2, imagen 1 de 1
    • Remove the screws securing the plates to the cabinet doors using a Phillips #0 screwdriver. Remove the plates.
    • Do this on the both sides.
  3. Cabinet Magnetic Catch Replacement: paso 3, imagen 1 de 3 Cabinet Magnetic Catch Replacement: paso 3, imagen 2 de 3 Cabinet Magnetic Catch Replacement: paso 3, imagen 3 de 3
    • Place the new magnetic catch on the center of the shelf cabinet.
    • Ensure it is adjusted carefully by moving its width halfway out of the cabinet and aligned on each side.
  4. Cabinet Magnetic Catch Replacement: paso 4, imagen 1 de 1
    • With your graphite pencil, mark the location of the screw holes so you know exactly where you placed it in case you get lost.
  5. Cabinet Magnetic Catch Replacement: paso 5, imagen 1 de 1
    • Screw in two 10 mm screws on the new magnetic catch using a Phillips #0 screwdriver to secure it in place.
    • Ensure that you are maintaining alignment of the magnetic catch with the help of Step 4. Otherwise, you will repeat Step 3.
    • You may reuse the old screws from the removal in Step 1 to install the new magnetic catch.
  6. Cabinet Magnetic Catch Replacement: paso 6, imagen 1 de 1
    • Close the cabinet and mark down the side of the cabinet door using a graphite pencil.
    • Do this on the other side.
  7. Cabinet Magnetic Catch Replacement: paso 7, imagen 1 de 1
    • Screw in one 5mm screw on the new magnetic plate using a Phillips #0 screwdriver to secure it in place on one side of the cabinet door.
    • Ensure that you are maintaining alignment of the magnetic plates with the help of Step 6 and old screw holes.
    • Do this step on the other side with the second 5mm screw.
    • You may reuse the old screws from the removal in Step 2 to install the new magnetic plates.
  8. Cabinet Magnetic Catch Replacement: paso 8, imagen 1 de 3 Cabinet Magnetic Catch Replacement: paso 8, imagen 2 de 3 Cabinet Magnetic Catch Replacement: paso 8, imagen 3 de 3
    • Test the cabinet magnetic catch by closing it.
    • You are finished when the cabinet stays closed after letting your hands go.
Conclusión
You have finished the replacement of cabinet magnetic catch.
Una persona más ha completado esta guía.
Brian Hegina
Miembro Desde 06/30/21
184 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 30
Ultimos 30 días: 138
Todo El Tiempo: 3,235
