Saltar al contenido principal
CR-10S/DDX Linear Rail Kit Hotend Installation
Qué necesitas
  1. CR-10S/DDX Linear Rail Kit Hotend Installation, Hotend Removal down: paso 1, imagen 1 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, Hotend Removal down: paso 1, imagen 2 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, Hotend Removal down: paso 1, imagen 3 de 3
    • Remove the Hotend cover screw
    • Remove the Hotend mounting screws
  2. CR-10S/DDX Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: paso 2, imagen 1 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: paso 2, imagen 2 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: paso 2, imagen 3 de 3
    • Loosen Idler pulley bracket screws and remove the idler pulley bracket
    • Remove the belt
    • Remove the lower V-slot wheel bolt from X-carriage
  3. CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: paso 3, imagen 1 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: paso 3, imagen 2 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: paso 3, imagen 3 de 3
    • Follow the table for the recommended mounting locations
    • Take note to skip 2 holes between fasteners, and make sure to mirror this process from each of the end of the rail until you meet in the middle.
    • For rails with an odd number of mounting holes, the pattern will overlap in the middle
    • For rails with an even number of mounting holes, the pattern will be continued across the rail
    • Pre-install all the M3x8 SHCS screw and Sliding T-nuts
    • Install the Printed T-nut guide on the end of the X axis extrusion, and slide the rail on to the X-axis from Right to left
    • The guide helps to slide the T-nuts into the extrusion
  4. CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting the Rail: paso 4, imagen 1 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting the Rail: paso 4, imagen 2 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, Mounting the Rail: paso 4, imagen 3 de 3
    • Slide the rail until you have about 2-3 mm between the rail and the end of the X axis extrusion.
    • Use both Linear rail Guide to center the rail to the Aluminum extrusion
    • Tighten the mounting screws as you go down. Making sure to slide down, slide the linear rail guide down as each screw is tightened.
  5. CR-10S/DDX Linear Rail Kit Hotend Installation, X Carriage install: paso 5, imagen 1 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, X Carriage install: paso 5, imagen 2 de 3 CR-10S/DDX Linear Rail Kit Hotend Installation, X Carriage install: paso 5, imagen 3 de 3
    • Belt adaptor
    • 4x M3x8 SHCS
    • 3x M3 split washers
    • M3 Hex nuts
    • Install the M3x8 SHCS screw with M3 Split washer in to the X carriage adaptor plate and mount to the Rail block.
    • Push up on the belt bracket, it is square against the bottom of the carriage block.
    • Note: If screws will not start, threading in. Spin the screws counterclockwise until you hear a click, and then tighten the screws evenly in an X pattern until they are fully tightened. This is to ensure that the threads do not get damaged.
    • Note, reference Hotend Mounting Instructions section before mounting the MGN 12 Adaptor Plates to the linear rail block. For installing Hex Nuts to the back of the Adaptors.
  6. CR-10S/DDX Linear Rail Kit Hotend Installation, Stock Hotend Install: paso 6, imagen 1 de 1
    • BL Touch and Fan Cover
    • M3x8 SHCS (2 mm longer than stock)
    • This screw replaces the M3x8 SHCS mount screw
    • M3x14 SHCS (8-10 mm longer than stock)
    • Hotend mounting screws
    • M3x22 SHCS (6 mm longer than stock) (Stock hotend)
    • M3x22 FHCS (6 mm longer than stock) (Stock hotend)
  7. CR-10S/DDX Linear Rail Kit Hotend Installation, DDX Install: paso 7, imagen 1 de 1
    • M3x28 SHCS & 2 Split lock washer(6 mm longer than stock) (Stock hotend)
Linea de Meta
2 personas más completaron esta guía.
AJ Pereira
Miembro Desde 05/29/20
2,707 Reputación
16 Guías creadas
Equipo
Tiny Machines 3D Miembro de Tiny Machines 3D
Community
Miembros de 5
41 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 1,859
