Saltar al contenido principal
CM Storm QuickFire Rapid Large Keycap Replacement
Qué necesitas
  1. CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: paso 1, imagen 1 de 3 CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: paso 1, imagen 2 de 3 CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: paso 1, imagen 3 de 3
  2. CM Storm QuickFire Rapid Large Keycap Replacement: paso 2, imagen 1 de 1
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid Large Keycap Replacement: paso 3, imagen 1 de 3 CM Storm QuickFire Rapid Large Keycap Replacement: paso 3, imagen 2 de 3 CM Storm QuickFire Rapid Large Keycap Replacement: paso 3, imagen 3 de 3
    • Install the plastic rings on the new keycap. The overhang needs to be ‘facing forward’ so that when the keycap is placed back on the board, the overhang is furthest away from you. When attaching the new key to the board, the ends of the metal bar on the board will go through these rings.
Conclusión
Equipo
Cal Poly, Team 6-23, Maness Fall 2014 Miembro de Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 5,522
