Saltar al contenido principal
CHI Spin N Curl Rotating Curler Rotating Barrel Replacement
Qué necesitas
  1. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Power Cord: paso 1, imagen 1 de 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 2, imagen 1 de 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 3, imagen 1 de 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 3, imagen 2 de 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 4, imagen 1 de 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 4, imagen 2 de 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 5, imagen 1 de 3 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 5, imagen 2 de 3 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 5, imagen 3 de 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Heating Element: paso 6, imagen 1 de 1
    • After following steps to open the CHI Spin N Curl, locate the heating element.
    • Remove screws on both sides of the heating element.
    • Once screws have been removed, then remove the heating element component.
    • Replace heating element once the original has been removed.
  7. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Rotating Barrel: paso 7, imagen 1 de 1
    • Remove all visible screws located near the barrel of the CHI Spin N Curl utilizing a Phillips #00 screwdriver.
    • Screws will be small and black.
  8. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 8, imagen 1 de 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: paso 8, imagen 2 de 2
    • Remove all screws located near wires using a Phillips #00 screwdriver.
    • Once all surrounding screws have been removed, detach the rotating barrel.
    • Gently remove the rotating barrel and replace once removed.
Conclusión
2 personas más completaron esta guía.
Annalise White
Miembro Desde 10/26/22
530 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Miembro de UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 604
