Saltar al contenido principal
CHI Original Power Cord Replacement
Qué necesitas
  1. CHI Original Power Cord Replacement, Hinge Spring: paso 1, imagen 1 de 2 CHI Original Power Cord Replacement, Hinge Spring: paso 1, imagen 2 de 2
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Power Cord Replacement: paso 2, imagen 1 de 1
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Power Cord Replacement: paso 3, imagen 1 de 1
    • Remove the hinge pin.
  4. CHI Original Power Cord Replacement: paso 4, imagen 1 de 1
    • Separate the two halves of the CHI Original.
  5. CHI Original Power Cord Replacement: paso 5, imagen 1 de 2 CHI Original Power Cord Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Power Cord Replacement, Power Cord: paso 6, imagen 1 de 2 CHI Original Power Cord Replacement, Power Cord: paso 6, imagen 2 de 2
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Power Cord Replacement: paso 7, imagen 1 de 1
    • Gently pull upwards on the connection point and disconnect the power cord.
Conclusión
Eric Knigga
Miembro Desde 08/23/17
215 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G2, Freund Fall 2017 Miembro de IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 Miembros
3 Guías creadas
5 comentarios
Do you know where to get a replacement power cord?
Taylor Bradford - Contestar
How/where do you purchase the replacement cord?
fixitman - Contestar
Where do you order an actual cord from??
Kelly Hickman - Contestar
Where we can get Power Cord?
Nazim - Contestar
Bonjour Nazim, j'ai trouvé le bon câble pour réparer le modèle GF1001EUN Farouk Systems USA sur le site web de pgservice :
Hi Nazim, I found the right cable to repair the GF1001EUN Farouk Systems USA model on the pgservice website :
https://pgservice.cc/fr/products/gammapi...
Sonny -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 37
Ultimos 30 días: 123
Todo El Tiempo: 6,159
