Saltar al contenido principal
CASIO mw240-1bv Battery Replacement
Qué necesitas
  1. CASIO mw240-1bv Battery Replacement, Battery: paso 1, imagen 1 de 3 CASIO mw240-1bv Battery Replacement, Battery: paso 1, imagen 2 de 3 CASIO mw240-1bv Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the four screws from the back of the watch.
    • Remove the back cover of the watch.
  2. CASIO mw240-1bv Battery Replacement: paso 2, imagen 1 de 3 CASIO mw240-1bv Battery Replacement: paso 2, imagen 2 de 3 CASIO mw240-1bv Battery Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to pull the small metal piece to the right slightly to allow the battery to pop out.
    • Replace battery with a SR626SW watch battery.
    • The battery may spring out very suddenly.
    • If your battery is swollen, handle it with care and dispose of it through an e-waste center or ask an electronics store. Do not dispose of it in the garbage.
  3. CASIO mw240-1bv Battery Replacement: paso 3, imagen 1 de 2 CASIO mw240-1bv Battery Replacement: paso 3, imagen 2 de 2
    • If the rubber seal pops out, realign the rubber seal with the groove along the back face.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 57
Ultimos 30 días: 247
Todo El Tiempo: 5,517
