Saltar al contenido principal
CASIO fx-50FH II Scientific Calculator Battery Replacement
Qué necesitas
  1. CASIO fx-50FH II Scientific Calculator Battery Replacement, Battery: paso 1, imagen 1 de 1
    • To turn the calculator off, first press the "shift" button.
    • Release the "shift" button, then press the "AC" button.
  2. CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 2, imagen 1 de 2 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 2, imagen 2 de 2
    • Place the calculator face down, then use a Phillips #00 screwdriver to remove the single screw securing the battery hatch in the top right corner.
  3. CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 3, imagen 1 de 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 3, imagen 2 de 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 3, imagen 3 de 3
    • Push the battery hatch to the right until it slides off.
  4. CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 4, imagen 1 de 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 4, imagen 2 de 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 4, imagen 3 de 3
    • Put on a pair of protective gloves before handling the battery to eliminate the risk of chemical burns.
    • Insert the tip of a spudger into the indent on the right-hand side of the battery to lift the edge of the battery up.
    • Lift the battery up and out.
  5. CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 5, imagen 1 de 1
    • Inspect the battery compartment any alkaline residue.
    • If no residue is present, skip to Step 7.
  6. CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 6, imagen 1 de 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 6, imagen 2 de 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 6, imagen 3 de 3
    • Use a cotton swab dabbed with white vinegar to wipe the alkaline off the battery compartment.
    • Use a dry cotton swab to remove the vinegar and alkaline residues.
    • Let the battery compartment dry completely.
  7. CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 7, imagen 1 de 1
    • Insert a new LR44 1.5V alkaline button battery into the compartment, with the positive sign facing up.
  8. CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 8, imagen 1 de 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 8, imagen 2 de 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 8, imagen 3 de 3
    • Reattach the battery hatch by sliding the hatch in from the right to the left.
  9. CASIO fx-50FH II Scientific Calculator Battery Replacement: paso 9, imagen 1 de 1
    • Use a Phillips #00 to secure the screw.
Conclusión
You have successfully replaced the battery of  a CASIO fx-50FH II Scientific Calculator!
Una persona más ha completado esta guía.
Cheuk Wai Chan
Miembro Desde 07/05/22
196 Reputación
1 Guía escrita
Equipo
2 comentarios
Very nice guide! I found the pictures to be very good and corresponding to the steps very well.
Frank Loi - Contestar
Thank you for the steps. I followed the steps and managed to salvage my calculator which I almost had to throw away. This has helped reduce waste. :)
Nancy Yeo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 93
Todo El Tiempo: 896
