Saltar al contenido principal
CASIO CDP-230R Pitch Bend Replacement
Qué necesitas
  1. CASIO CDP-230R Pitch Bend Replacement, Panels: paso 1, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement, Panels: paso 1, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement, Panels: paso 1, imagen 3 de 3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
  2. CASIO CDP-230R Pitch Bend Replacement: paso 2, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 2, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 2, imagen 3 de 3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
  3. CASIO CDP-230R Pitch Bend Replacement: paso 3, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 3, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 3, imagen 3 de 3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
  4. CASIO CDP-230R Pitch Bend Replacement: paso 4, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 4, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 4, imagen 3 de 3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
  5. CASIO CDP-230R Pitch Bend Replacement: paso 5, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 5, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 5, imagen 3 de 3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
  6. CASIO CDP-230R Pitch Bend Replacement: paso 6, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 6, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 6, imagen 3 de 3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
  7. CASIO CDP-230R Pitch Bend Replacement: paso 7, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 7, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 7, imagen 3 de 3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
  8. CASIO CDP-230R Pitch Bend Replacement: paso 8, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 8, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement: paso 8, imagen 3 de 3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
  9. CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: paso 9, imagen 1 de 3 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: paso 9, imagen 2 de 3 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: paso 9, imagen 3 de 3
    • Remove the two 8mm x 1.5mm J screws from the inside of the side panel by using a J1 head screwdriver.
    • Slide the pitch bend out of the side panel.
  10. CASIO CDP-230R Pitch Bend Replacement: paso 10, imagen 1 de 2 CASIO CDP-230R Pitch Bend Replacement: paso 10, imagen 2 de 2
    • Follow the white and orange cable to the white end that is attached to the button panel
    • Pinch the white end and pull the cord out
  11. CASIO CDP-230R Pitch Bend Replacement: paso 11, imagen 1 de 1
    • Run the white and orange cable through the innermost side panel and pull out
Conclusión
Una persona más ha completado esta guía.
Areli Reyes
Miembro Desde 10/01/17
545 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G2, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 583
