Introducción
This guide will teach you how to replace the main circuit board in the CASIO CDP-230R.
Qué necesitas
Flip the keyboard upside down, with the keys on a flat surface.
Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
Grab the center of the front panel with two hands and lift to remove panel.
Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
The main circuit board is located on the green side of the button panel. The main circuit board is the smaller green board.
Grasp the white ribbon lined with foam and pull up to remove from the main circuit board.
Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver.
2 personas más completaron esta guía.
2 comentarios
Уважаемый fixit это димитрий фенетов твой чертовски мертвый
дорогой ifixit ваша ложь не является исключительной
