Introducción
¿Cómo desmontar el conector si el cable está dañado?
Qué necesitas
Para desmontar el conector en T, debe cortar el cable a 1 cm del conector.
Saca el resto del cable.
Tome una varilla de hierro de 4-5 mm de diámetro y saque el interior del conector a través del orificio del cable.
Es más conveniente hacer esto en un pequeño tornillo de banco
Pase el termorretráctil y la parte exterior del conector sobre el cable.
Alambres de soldadura
De fábrica, GND simplemente está engarzado con una pieza de hierro, pero también lo soldé para mayor confiabilidad.
Ensamblar conector
Es muy fácil volver a presionarlo con un pequeño tornillo de banco.
6 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Luis Roberto nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
3 comentarios
Thank you very much for this guide, also with the pictures. This was really helpful.
I would like to say, that the time required was a lot more for me, about 3 hours in total.
My cable fell apart and the cable coating came off, so I have applied a heat shrink sleeving first over the part of the cable without the cable coating, then another sleeving above the whole cable.
The connector was glued inside, so it was difficult to get off the cap and later to get rid of the old cable, which was still stuck inside. After drilling into the metal crimped part, I could remove the remainders of the old cable.
Now I'm really happy, that the cable is renewed and that it works well.
For me sadly this tutorial didn't work. My connector was also glue on the inside and circuit was covered with some sort of resin. I destroyed part of a circuit while removing remaining cable from the charging circuit. I later figured out that it would be better to salvage parts of charging cable that were still sticking out of magsafe 2 connector, connect them in wire and protect with heat-shrink tubbing. Maybe next time.
I still have to say thanks to the author of this tutorial, since I think repair is our hope out of grand consumerist culture.
I do hope my comment serves as a warning to fellow fixers when dealing with original apple chargers.
