Saltar al contenido principal
Cómo solucionar los problemas de desconexión de Mobee Magic Mouse
Qué necesitas
Linea de Meta
30 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
en es
100%
¡ Ale Mantellini nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Peter Barnett
Miembro Desde 09/04/16
732 Reputación
1 Guía escrita
Equipo
4 comentarios
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Contestar
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Contestar
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Contestar
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 50
Ultimos 30 días: 235
Todo El Tiempo: 36,878
