Introducción
Ir al paso 1 ↓¿Tus persianas no se retraen como se supone que deben hacerlo? Si tus persianas se extienden cuando se bajan pero no se retraen cuando se empujan hacia arriba, es probable que la cuerda que pasa por las persianas se haya caído de la polea dentro de la carcasa superior. Sin embargo, no te preocupes, ya que hay una manera de resolver esto. Esta guía te ayudará a solucionar esta maldita molestia.
Qué necesitas
Herramientas
Phillips #2 Screwdriver$16.954.6
This might be needed to remove you blinds from the wall, depending on the mount.
Retira los clips que mantienen las persianas unidas a la pared.
¡Disfruta de tus persianas retráctiles!
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
2Guía Comentarios
Cordless. This is not a cordless shade. Try again.
These aren't instructions for CORDLESS but I wasn't able to find any. I was able to repair the broken cord of my cordless blind; it took a couple hours but it's as good as new. Surprisingly, the tension cord for both sides is actually one continual cord. You'd want to replace both sides if yours is different. Nylon Cord 1.4mm worked for me. It does help if you have another blind to use as a guide on how to thread the pulleys especially if both sides break (which happened to me). Maybe I'll make a video on my next broken cord. Hint: When you measure the length of the cord, add extra feet before you cut the new cord.
