Introducción
Follow this guide to remove and disassemble the traveling valve. You can then inspect or replace the valve, itself, or any of its components.
Qué necesitas
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
Use a pipe wrench to loosen and remove the pump spout.
Place the spout on a clean surface to prevent any contamination.
Place one wrench on the top of one of the pump riser plate bolts.
Place another wrench around the bottom of the bolt.
Pull the wrenches apart to loosen the bolt.
Insert a wrench into the slots located at the bottom of the traveling valve.
Using another wrench for leverage, unscrew the valve off the pump rod.
