Introducción
Follow this guide to remove a bush pump's head and handle for repair or replacement. Be sure to use at least two people when following this guide to prevent injury, as the pump head can be heavy.
  1. Test pump performance by pumping 40 strokes. An effective pump should return at least 10 liters.
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Remove the two pins connecting the handle to the slider. Remove the two pins connecting the handle to the slider.
    • Remove the two pins connecting the handle to the slider.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Pull the two lever arms away from the slider. Pull the two lever arms away from the slider.
    • Pull the two lever arms away from the slider.
  5. Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame. Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  6. Throughout this step, make sure you support the handle and head with at least three hands. Slide the bearing rod out of the head. Inspect the bearing rod and head for any wear or tear.
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  7. Remove the head and handle, and place them on a clean surface to prevent contamination.
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
Conclusión
Jake Devincenzi
Miembro Desde 18/04/11
108,109 Reputación
57 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 98
