Introducción
This guide will walk you through the procedure to remove the above grade riser pipe. You can then replace it with a new one, or perform any necessary repairs on it.
Qué necesitas
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
2 personas más completaron esta guía.
