Saltar al contenido principal
Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement
Qué necesitas
  1. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Detach the seat from the frame: paso 1, imagen 1 de 1
    • Push both the white square buttons under the seat at the same time, to remove the seat from the frame.
  2. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement: paso 2, imagen 1 de 1
    • Put the frame with the handle on the ground like shown in the picture, to have better access to the swivel wheels.
  3. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Detach swivel wheel: paso 3, imagen 1 de 1
    • Press the button above the swivel wheel, and pull out the swivel wheel
  4. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: paso 4, imagen 1 de 3 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: paso 4, imagen 2 de 3 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: paso 4, imagen 3 de 3
    • Remove the two screws on the black cylinder on the bottom with the Torx screwdriver.
    • Make sure not to lose the screws, since you need them for the reassembly later.
  5. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement: paso 5, imagen 1 de 1
    • Remove the bottom part of the cylinder. You can use your screwdriver to pull it out.
  6. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: paso 6, imagen 1 de 3 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: paso 6, imagen 2 de 3 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: paso 6, imagen 3 de 3
    • Push the old button, and place the flathead screwdriver behind the button
    • Push the button down and towards the opening of the cylinder.
    • Take out the wheel lock button and the spring, and make sure not to lose the spring.
  7. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attaching the new part: paso 7, imagen 1 de 2 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attaching the new part: paso 7, imagen 2 de 2
    • Pull the spring from the old part.
    • Attach it to pin on the new swivel wheel lock.
  8. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Placing the new part in the stroller: paso 8, imagen 1 de 1
    • Put the new part with the spring back inside the cylinder, in the orientation shown in the picture.
  9. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Reassembling: paso 9, imagen 1 de 1
    • Place the inner black cylinder back into the outer cylinder.
  10. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Securing the part: paso 10, imagen 1 de 2 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Securing the part: paso 10, imagen 2 de 2
    • Use the two screws and the Torx screwdriver to secure the parts.
  11. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attach the wheel: paso 11, imagen 1 de 1
    • Click the wheel back onto the frame.
  12. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Put the stroller the right side up.: paso 12, imagen 1 de 2 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Put the stroller the right side up.: paso 12, imagen 2 de 2
    • The repair is now finished. Flip the frame back onto four wheels.
    • Place the seat back onto the frame.
Linea de Meta
Una persona más ha completado esta guía.
Documentos Adjuntos
Rebecca Dowling
Miembro Desde 04/24/18
665 Reputación
3 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 2,390
