Saltar al contenido principal
Introducción
In order to switch the stitching styles of your sewing machine, the stitch select knob must be properly functioning. This guide will show the steps for replacement.
Partes
No se especificaron partes.
  1. Place the machine on a solid surface.
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Lay the machine on its side.
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the bottom panel.
    • Remove the bottom panel.
  6. Place the machine upright.
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  7. Adjust the knob to gain access to the phillips head screw.
    • Adjust the knob to gain access to the phillips head screw.
  8. Remove the 14mm Phillips #2 screw.
    • Remove the 14mm Phillips #2 screw.
  9. Remove the knob.
    • Remove the knob.
Conclusión
Una persona más ha completado esta guía.
Kevin Bickers
Miembro Desde 05/02/14
601 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 2-12, Amido Winter 2014 Miembro de Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 537
