Saltar al contenido principal
Brother XR-40 Lightbulb Replacement
Qué necesitas
  1. Brother XR-40 Lightbulb Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Lightbulb Replacement: paso 2, imagen 1 de 1
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Lightbulb Replacement: paso 3, imagen 1 de 1
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Lightbulb Replacement: paso 4, imagen 1 de 1
    • Remove the bottom panel.
  5. Brother XR-40 Lightbulb Replacement: paso 5, imagen 1 de 1
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  6. Brother XR-40 Lightbulb Replacement, Lightbulb: paso 6, imagen 1 de 1
    • Using scissors, clip the two zip ties securing the lightbulb wire.
  7. Brother XR-40 Lightbulb Replacement: paso 7, imagen 1 de 1
    • Place the machine on its side, with access to the bottom.
    • Gently pull out the white wire connecting the bulb to the machine.
  8. Brother XR-40 Lightbulb Replacement: paso 8, imagen 1 de 1
    • Move the wire out from under the plastic hook.
  9. Brother XR-40 Lightbulb Replacement: paso 9, imagen 1 de 1
    • Using the flathead screwdriver, remove the 5mm Flathead screw holding on the lightbulb bracket.
  10. Brother XR-40 Lightbulb Replacement: paso 10, imagen 1 de 1
    • Remove the lightbulb assembly.
Conclusión
Una persona más ha completado esta guía.
Kevin Bickers
Miembro Desde 02/05/14
673 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 2-12, Amido Winter 2014 Miembro de Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 16
Todo El Tiempo: 3,064
