Saltar al contenido principal
Brother XM3700 Broken Needle Replacement
Qué necesitas
  1. Brother XM3700 Broken Needle Replacement, Broken Needle: paso 1, imagen 1 de 3 Brother XM3700 Broken Needle Replacement, Broken Needle: paso 1, imagen 2 de 3 Brother XM3700 Broken Needle Replacement, Broken Needle: paso 1, imagen 3 de 3
    • Adjust the needle with the handwheel towards you until it is at the highest position, as indicated by the silver thread take-up lever.
  2. Brother XM3700 Broken Needle Replacement: paso 2, imagen 1 de 2 Brother XM3700 Broken Needle Replacement: paso 2, imagen 2 de 2
    • Unscrew the bolt that holds the needle in place using either the tool that came with your Brother machine, or a small flat object like a coin.
  3. Brother XM3700 Broken Needle Replacement: paso 3, imagen 1 de 2 Brother XM3700 Broken Needle Replacement: paso 3, imagen 2 de 2
    • Remove the broken needle stem from the machine, and dispose of it carefully.
  4. Brother XM3700 Broken Needle Replacement: paso 4, imagen 1 de 2 Brother XM3700 Broken Needle Replacement: paso 4, imagen 2 de 2
    • Unthread the broken needle tip from the thread, and dispose of carefully.
  5. Brother XM3700 Broken Needle Replacement: paso 5, imagen 1 de 2 Brother XM3700 Broken Needle Replacement: paso 5, imagen 2 de 2
    • Select a Brother brand needle, using the needle size that works well with your fabric.
  6. Brother XM3700 Broken Needle Replacement: paso 6, imagen 1 de 2 Brother XM3700 Broken Needle Replacement: paso 6, imagen 2 de 2
    • Insert the needle with the flat side of the stem facing the back of the machine.
  7. Brother XM3700 Broken Needle Replacement: paso 7, imagen 1 de 1
    • Screw the bolt in first with your fingers and then with the tool until the needle is tightly secured.
  8. Brother XM3700 Broken Needle Replacement: paso 8, imagen 1 de 2 Brother XM3700 Broken Needle Replacement: paso 8, imagen 2 de 2
    • Rethread the needle and pull the thread through the back.
Conclusión
Congratulations! You have successfully replaced your broken needle. Happy sewing!
Una persona más ha completado esta guía.
Nadya Verick
Miembro Desde 02/07/23
178 Reputación
1 Guía escrita
Equipo
UC Davis, Team 1-6, Andersen Winter 2023 Miembro de UC Davis, Team 1-6, Andersen Winter 2023
UCD-ANDERSEN-W23S1G6
4 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 296
