Saltar al contenido principal
Brother Printer DCP-L2540DW Toner Cartridge Replacement
  1. Brother Printer DCP-L2540DW Toner Cartridge Replacement, Toner Cartridge: paso 1, imagen 1 de 1
    • Pull the center paper tray extender to expose the drum unit.
  2. Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 2, imagen 1 de 1
    • Gently pull the drum unit out of the printer at a slight incline angle.
  3. Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 3, imagen 1 de 2 Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 3, imagen 2 de 2
    • Push down on the lever lock to unlock the cartridge from the drum unit.
    • Remove the cartridge from the drum unit and recycle it.
  4. Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 4, imagen 1 de 2 Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 4, imagen 2 de 2
    • Unpack the new toner cartridge from its packaging.
    • Gently shake the cartridge to evenly distribute the toner throughout the printer transfer roller.
  5. Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 5, imagen 1 de 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 5, imagen 2 de 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 5, imagen 3 de 3
    • Remove protective cover enclosing the printer transfer roller
    • AVOID CONTACT WITH PRINTER TRANSFER ROLLER. This could potentially damage the device.
    • Insert the new cartridge in the drum unit.
    • A click should be heard to acknowledge the toner cartridge has been fitted properly.
  6. Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 6, imagen 1 de 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 6, imagen 2 de 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 6, imagen 3 de 3
    • Clean the corona wire with the slide tab near the front side of the drum unit by sliding it left and right several times.
    • Return the slide tab back to its original position before continuing.
  7. Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 7, imagen 1 de 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 7, imagen 2 de 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: paso 7, imagen 3 de 3
    • Insert the drum unit with the new toner cartridge attached at a slight incline back into the printer.
    • Remember to have the drum unit pushed in enough for the front cover to be able to close.
    • You have now successfully completed replacing the toner cartridge for your Brother DCP-L2540DW Printer.
Conclusión
Garvish Patel
Miembro Desde 05/12/21
145 Reputación
1 Guía escrita
Un comentario
I have done this process and the printer is still telling saying that we need to put in toner?? Can not figure out why?? Any help??
Ed Reinstein - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 54
Ultimos 30 días: 203
Todo El Tiempo: 5,714
