Saltar al contenido principal
Brother PT-D200 Cutter Blade Replacement
  1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: paso 1, imagen 1 de 2 Brother PT-D200 Cutter Blade Replacement, Cutter Blade: paso 1, imagen 2 de 2
    • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  2. Brother PT-D200 Cutter Blade Replacement: paso 2, imagen 1 de 1
    • Locate the cutter blade unit (mint green) as shown in the picture.
  3. Brother PT-D200 Cutter Blade Replacement: paso 3, imagen 1 de 2 Brother PT-D200 Cutter Blade Replacement: paso 3, imagen 2 de 2
    • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
    • The blade is sharp.
Conclusión
Blaire McCreary
Miembro Desde 01/24/14
201 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-16, Regan Winter 2014 Miembro de Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Miembros
6 Guías creadas
Un comentario
Where can you order the replacement blade?
mistymeziere - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 42
Todo El Tiempo: 3,084
