Saltar al contenido principal
Brother PT-90 Personal Labeler Disassembly
Qué necesitas
  1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: paso 1, imagen 1 de 2 Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: paso 1, imagen 2 de 2
    • Start with your device off. The screen should be blank and not displaying anything.
    • Turn the device over so it's resting face down.
    • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
  2. Brother PT-90 Personal Labeler Disassembly: paso 2, imagen 1 de 3 Brother PT-90 Personal Labeler Disassembly: paso 2, imagen 2 de 3 Brother PT-90 Personal Labeler Disassembly: paso 2, imagen 3 de 3
    • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
    • Remove the 4 batteries located on the left side of the device.
  3. Brother PT-90 Personal Labeler Disassembly: paso 3, imagen 1 de 3 Brother PT-90 Personal Labeler Disassembly: paso 3, imagen 2 de 3 Brother PT-90 Personal Labeler Disassembly: paso 3, imagen 3 de 3
    • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
  4. Brother PT-90 Personal Labeler Disassembly: paso 4, imagen 1 de 3 Brother PT-90 Personal Labeler Disassembly: paso 4, imagen 2 de 3 Brother PT-90 Personal Labeler Disassembly: paso 4, imagen 3 de 3
    • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
    • Remove all of the screws from the back of the device.
  5. Brother PT-90 Personal Labeler Disassembly: paso 5, imagen 1 de 2 Brother PT-90 Personal Labeler Disassembly: paso 5, imagen 2 de 2
    • Once the screws have been removed, press as shown on the fastener.
    • Carefully open the device.
Linea de Meta
Tessa Hathaway
Miembro Desde 10/13/16
127 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 697
