Saltar al contenido principal
Brother PT-1290 Face Plate Replacement
Qué necesitas
  1. Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: paso 1, imagen 1 de 3 Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: paso 1, imagen 2 de 3 Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: paso 1, imagen 3 de 3
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Brother PT-1290  Face Plate Replacement, Back of device: paso 2, imagen 1 de 3 Brother PT-1290  Face Plate Replacement, Back of device: paso 2, imagen 2 de 3 Brother PT-1290  Face Plate Replacement, Back of device: paso 2, imagen 3 de 3
    • Remove back of device and set aside.
  3. Brother PT-1290  Face Plate Replacement, Remove screws: paso 3, imagen 1 de 3 Brother PT-1290  Face Plate Replacement, Remove screws: paso 3, imagen 2 de 3 Brother PT-1290  Face Plate Replacement, Remove screws: paso 3, imagen 3 de 3
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. Brother PT-1290  Face Plate Replacement, Remove flat panel: paso 4, imagen 1 de 3 Brother PT-1290  Face Plate Replacement, Remove flat panel: paso 4, imagen 2 de 3 Brother PT-1290  Face Plate Replacement, Remove flat panel: paso 4, imagen 3 de 3
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  5. Brother PT-1290  Face Plate Replacement, Remove: paso 5, imagen 1 de 3 Brother PT-1290  Face Plate Replacement, Remove: paso 5, imagen 2 de 3 Brother PT-1290  Face Plate Replacement, Remove: paso 5, imagen 3 de 3
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
  6. Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: paso 6, imagen 1 de 3 Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: paso 6, imagen 2 de 3 Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: paso 6, imagen 3 de 3
    • Now that you have removed your keyboard. Turn the device over carefully.
    • Pop of LCD black cover.
    • Use the spudger to gently press out the LCD screen.
  7. Brother PT-1290  Face Plate Replacement, Switching out faceplate.: paso 7, imagen 1 de 1
    • Change out old damaged face plate with your new face plate.
Conclusión
Lorraine Canez
Miembro Desde 10/25/14
318 Reputación
3 Guías creadas
Equipo
Gateway, Team 1-4, Johnson Fall 2014 Miembro de Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 143
